Re: 3rd time AINT a charm with 50 Cub
Posted by CharlieU on October 10, 2013 at 19:36:23 from (199.86.19.63):
In Reply to: Re: 3rd time AINT a charm with 50 Cub posted by Farmallb on October 10, 2013 at 19:05:01:
The bushing is located in the center of the crankshaft where the flywheel bolts on. The driveshaft that goes from the transmission to the clutch. The front end of this shaft sticks into this bushing. The job of the bushing is to hold the shaft centered in the clutch. Bigger tractors have a ball bearing usually located in the center of the flywheel. Commonly called pilot bearing. I have seen these bushing in the smaller tractors like the CUBs, A, B, C, & I'm sure this bushing is used in the 100, 200 series of tractors as well. I hope this helps.
