Re: Farmall 706 final drives?
Posted by HydroTek on October 10, 2013 at 19:53:52 from (69.27.61.74):
In Reply to: Farmall 706 final drives? posted by John V. on October 10, 2013 at 17:13:41:
when next you have the PTO out, remove the large freeze plug from the inner axle bearing, the oil level will adjust to the main reservoir. Later models have this plug removed and also a hole near the bottom of the final drive housing, to circulate the oil.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
