Re: super C ignition
Posted by HydroTek on October 10, 2013 at 21:04:45 from (69.27.61.74):
In Reply to: super C ignition posted by sparky70 on October 08, 2013 at 08:52:09:
check the grounds as well, it only takes a small voltage drop to make the starter spin slow and also take voltage away from the coil.
You could run a ground straight from the battery to the starter and eliminate all those potential trouble spots. Never understood why the manufacturer thought it was cool to ground to the battery box or the steering column.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
