Posted by mkirsch on October 11, 2013 at 04:57:41 from (64.80.110.75):
In Reply to: super C ignition posted by sparky70 on October 08, 2013 at 08:52:09:
Yes there is, if it's the WRONG type of filter.
Most automotive fuel filters out there are for systems with fuel pumps, and will not gravity flow enough fuel to the carburetor. They work fine at first but they're barely keeping up. Get a little crud in them, and they can't flow enough fuel anymore. Then you come on the forum because your tractor won't start.
The kind of crud that does that would normally flow straight through the carburetor and out the exhaust on these old engines. Real fine stuff isn't a problem, the big flakes of rust are what get you.
If you start with a clean tank, and use clean fuel, there is absolutely no need for anything beyond the sediment bowl.
If putting a fuel filter on makes you sleep better at night, by all means. Just make sure you get the RIGHT one.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
