The throw out bearing does not support the shaft. It's supposed to be a loose fit because the bearing moves on a slight arc. If it wasn't loose it would bind on the shaft.
All the throwout bearing does is push against the three fingers on the clutch plate.
There's a little brass bushing in the center hole of the flywheel that the machined end of the shaft pokes into when you stab the tractor back together. That is what supports the shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
