Is assume Char-Lynn. Mine isn't slotted and fits well but close. I have a bolt through the coupler right below the unit on the steering shaft. I had to get rid of all of the extra threads once the nut was on as they hit the under side of the hood. The steering shaft does rub a bit on the hood just above the torque generator (where the shaft starts to run outside the hood). They sure didn't allow you any wiggle room.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
