Re: Bearings seals measurements for farmall A
Posted by Wm. Ecccles - Jardine on October 12, 2013 at 06:40:39 from (162.213.111.132):
In Reply to: Bearings seals measurements for farmall A posted by Wm. Ecccles - Jardine on October 10, 2013 at 12:36:07:
Dear CNKS:
To bring you up to date on progress of finding alternate numbers for the bearings & seals.
I found all the code numbers for the bearings & seals YET I didn't find alternate numbers for them so I could cross reference as many as possible. I wrote the agent IHC supplier / have not heard back asa yet ( as of Friday writing)
The only option I have is the Mike all the bearing spots O/D I/D and width, since I had / several months ago disassembled the areas in question due to water contamination and cleaned all parts; then going with this information to places such as Canada Bearing and others, find alternate compatible bearings HOPEFULLY at less cost that the quoted one from IHC in Woodstock Ont.
Maybe the info is on the IHC sight >> BUT I AM A FUMBLE FINGERS when it comes to using the computer { IF I make a mistake by pushing the wrong button I have known me to take up to to hours to figure out which one I pushed and then
correct it} so I have not been able to ferret out this info form the IHC sight.
If you have any other information in this regards I would appreciate it You may email me @ williamecclesjardine@yahoo.ca
Thank you.
