Re: Farmall M/SM with under tank battery
Posted by Zachary Hoyt on October 12, 2013 at 08:51:21 from (184.12.72.119):
In Reply to: Re: Farmall M/SM with under tank battery posted by kopeck on October 12, 2013 at 06:28:11:
The other thing you can sometimes do is turn the battery around so
the grounded terminal is toward the starter and the hot terminal is
toward the switch. That has worked for me to help keep the cables
short.
Zach
