Re: Gauge bracket for ps onSm
Posted by DTK on October 12, 2013 at 11:08:52 from (64.72.185.47):
In Reply to: Gauge bracket for ps onSm posted by DTK on October 11, 2013 at 11:40:58:
Thanks for the replies, any more info would be appreciated. I slotted the top two holes in the casting a little and I will grind some metal off the top of where the gauges are mounted. Hopefully that will be all I need. Thanks DTK.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
