Re: c-123 engine into farmall super c???
Posted by SDE on October 12, 2013 at 13:18:14 from (174.124.134.196):
In Reply to: c-123 engine into farmall super c??? posted by Roger Kemp on October 12, 2013 at 12:38:25:
If the flywheel is the same for both engines and the starter drives are the same diameter, it should not be a problem where the stater is located, as long as you use the tractors original bell housing.
But I really don't know, and I did not stay at a Holiday Inn Express last night.
SDE
