Re: c-123 engine into farmall super c???
Posted by El Toro on October 13, 2013 at 04:49:46 from (96.244.7.206):
In Reply to: Re: c-123 engine into farmall super c??? posted by Boonville Kid on October 12, 2013 at 14:32:04:
That only affects the cid. Should give a little more power. The valves should be ground while the engine is torn down and carburetor should be ok. If you're going to work the tractor I would use at least 89 octane gas. The area where the sleeve seals are should be cleaned of any rust or crud so there's no coolant blockage. Have your local auto machine shop to grind the valves if any are too thin replace them. Hal
