Posted by StuartR on October 13, 2013 at 12:19:09 from (88.111.121.208):
Hi again all, since my last post, I have bypassed the equaliser valve on the advice of the knowledgable Bernard le mecano. Only different thing I did was rather than just replace the tee's for elbows, I made an equaliser manifold in the lathe so that the brakes are permanently equalised (as I have the pedals bolted together due to a worn pedal shaft and I figured that if the brakes were unequally worn I would get unbalanced braking without equalising the pressure in each service). Apart from a small leak on one pipe, I thought this would do the trick. However, after bleeding the brakes all was good, engine stopped for about 30 mins & still good, engine off & pedal remaining hard, left overnight and back to soft peal and pumping the brakes again!!!!!. I just don't know where to next, should I replace the seals in the master cylinders? even though there appears to be no leaks. I still don't think it's the wheel cylinder seals as when they work, they are perfect until the engine is stopped, if the wheel cylinder o rings were rolling, surely they would do this whether or not the engine was running?? It seems to be something that is affected on the engine start up, as sometimes I start up and all is well, other times it's not, I'm on the point of giving up!!! Please help..
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
