Re: Farmall M falls flat on its face
Posted by Bud Kaiser on October 13, 2013 at 15:36:44 from (216.45.93.230):
In Reply to: Farmall M falls flat on its face posted by FarmallKeith on October 13, 2013 at 10:04:31:
It might have a intake manifold leak.This will also cause a high idle.Does it miss or cut out or just pull down. I have pulled against what I believe are stock M"s and they usually don"t power out unless above 6100 lb class.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
