Re: intl 300 Utility
Posted by 504-1 on October 13, 2013 at 18:28:14 from (199.127.54.155):
In Reply to: intl 300 Utility posted by anallisguy on October 13, 2013 at 08:09:22:
One place to look is the coil, the wire going to the distributor is the ground wire. Pos ground will have the Pos wire from the coil going to the distributor, Neg ground will have the Neg coil wire going to the Dis. Of course there is nothing to prove what has been changed in the past as DeltaRed has said.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
