Posted by Janicholson on October 13, 2013 at 19:57:25 from (74.60.94.18):
In Reply to: H drive shaft posted by Gene Eggen on October 13, 2013 at 19:32:03:
If the hydraulic pump still works with the clutch out and the tractor in gear, the counter shaft and the constant mesh gear are still working. That means the PTO is still working. If it will will not drive the rear wheels in 5th gear (as it would when starting out in that gear) then the issue is in the output shaft It has the differential pinion on it, or in the differential. (if it has a hand clutch aftermarket device that could be broken) With it running and in 4th gear, (I assume not moving) step on the brakes. If that loads the engine, the issue is in the fina drives and or a broken axle. Let us know from these tests. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
