Re: h with 3point plow???
Posted by FBH44 on October 14, 2013 at 03:39:43 from (64.85.215.169):
In Reply to: h with 3point plow??? posted by jhakenwerth on October 13, 2013 at 15:45:07:
I plow with a 1950 "H", a Cross Manufacturing 3-point, and a JD 812 2-14 with depth wheel. It would not work with0ut adjusting the top link to plow level. It wouldn"t wortk without the depth wheel, which I can set to any depth. And it absolutely will not work without a turn-buckle anti-sway gizmo I made to hold the first plow 14" from the inside of the rear wheel, so the first cut is 14". But it works great. You"re up high above the plow, you can hear the ssshhhhh as it cuts.
