Remove transmission top, slide axles out enough to remove bull gears. Remove brakes, bull pinion gears and then differential carrier housings. If the 560 has all updates, tapered bearings are used to support the differential housing and a special tapered shim used on one side. Can't remember if the differential housing will wiggle out if the left side carrier housing is left in place. Depending on what's going on you may need it out anyway.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
