Re: Farmall M falls flat on its face
Posted by dej(Jed) on October 14, 2013 at 07:23:15 from (141.189.113.1):
In Reply to: Farmall M falls flat on its face posted by FarmallKeith on October 13, 2013 at 10:04:31:
You did not say how far you pulled. If you got over 100 feet or so, you did well. An old M with standard tires and a drawbar isn't going to take it out to a full pull range. If you change out your low gear , you will double your HP.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
