Re: Farmall M falls flat on its face
Posted by Tom Fleming on October 14, 2013 at 17:42:50 from (67.20.233.75):
In Reply to: Farmall M falls flat on its face posted by FarmallKeith on October 13, 2013 at 10:04:31:
Well, this summer, I pulled my 1938 F30 narrow tread in the 5500 class and the 6500 class. Both times, I ran out of traction just as the governor kicked in. I know 5-10 feet is alot in a tractor pull, but that old F30 stayed within 10 feet of the SM's and similar. They ran out of power, I ran out of traction. Go figure.
I have done nothing to that engine except tune it up, adjust the valves and redid the carb (stock).
a tuned up M, that isn't "tired" will pull and pull well. Get the timing right, make sure the valves are seating and adjusted correctly. Clean, correctly set carb. Let 'er rip. she will run good. If she is tired and a little worn out, not so much.
If you are truly looking to spend a little money and get the biggest bang for the buck. New rings, hone the sleeves, valve job, and get the carb/governor right. she will surprise you.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
