Re: Re: Re: Farmall C governor
Posted by big fred on December 04, 2000 at 20:30:34 from (208.51.245.143):
In Reply to: Re: Re: Farmall C governor posted by Chris on December 04, 2000 at 13:49:06:
Okay, I get it now. The governor doesn't come off with the housing, it is mounted on the distributor drive gear. You can slide the thrust sleeve and thrust bearings off to inspect them once you have the housing removed.
Post A Followup
: Re: Re: Re: Re: Farmall C governor
