Re: Ongoing carburator problem SMTA
Posted by Rick on December 04, 2000 at 21:06:10 from (63.82.131.161):
In Reply to: Ongoing carburator problem SMTA posted by Dan on December 04, 2000 at 18:09:11:
Had the same problem with Super M the carburator was freezing up at the Carb and Manifold, this was iceing up in the ideal air jet, black smoke bad ideal then die. Make sure you have a good gasket and the carb is tight and not sucking air.
Post A Followup
: Re: Re: Ongoing carburator problem SMTA
