300 utility rear axle hub
Posted by nj tom on October 15, 2013 at 06:11:48 from (108.35.245.53):
Hey Guys, I finally got around to replacing the rear outer axle seals (which I got at NAPA thanks to you guys), but I ran into a little problem. 1 rear axle hub has 4 cracks in the machined shoulder that the seal rides on. It is definitely on borrowed time. What i would like to know before I start searching around for a used one, is if that is hub the same on any other International models? the part # is 361 583 R1. If anyone knows if that hub is used on any other models it would make it alot easier to find. Thank you in advance for all your help, Tom
