Re: need more front height on a C-SC, ideas?
Posted by SDE on October 15, 2013 at 07:11:55 from (174.124.134.196):
In Reply to: need more front height on a C-SC, ideas? posted by NoNewParts on October 15, 2013 at 06:49:55:
How much higher do you want to make the front ride?
I would take two pieces of 1/2" flat stock, that are the same size as the top of the lower pedestal. Let us say that it is 4" wide and 4" long. Drill the 4 mounting holes in each piece. Now I would weld these two pieces to a spacer to get the height that you want. The spacer could be a piece of round or rectangular tube stock. You would then need to buy 4 more nuts and bolts.
SDE
