Re: H & M slow first gears.
Posted by Smitholm on October 15, 2013 at 07:50:56 from (71.58.91.48):
In Reply to: H & M slow first gears. posted by dej(Jed) on October 15, 2013 at 05:21:16:
Horsepower is defined as the pull required to move the load multiplied by the speed at which the load is being moved. So, for the same horsepower (same motor), if the speed is reduced, the pulling capability is increased proportionately. So, for example, if the ground speed is reduced by half by changing gearing, the pull is doubled, assuming that the traction is sufficient to support it.
