Re: Farmall M falls flat on its face
Posted by mkirsch on October 15, 2013 at 12:55:46 from (64.80.110.75):
In Reply to: Farmall M falls flat on its face posted by FarmallKeith on October 13, 2013 at 10:04:31:
Did you get the tab aligned correctly with the notch when you put the carburetor back on the tractor?
If you miss to one side, it will not rev up.
If you miss to the other side, it will not idle down.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
