Re: Can anyone tell me which model I have a Super C or 200 ?
Posted by gene b on December 05, 2000 at 03:22:48 from (63.42.174.66):
In Reply to: Can anyone tell me which model I have a Super C or 200 ? posted by Toyfarmer on December 04, 2000 at 23:29:06:
sounds like a hi-clear model what size are the fronts if they are 19 in rims its a hi-clear look under the #1 plug there should be a flat machined place with a number stamped in if the prefix says fav its a SA hi-clear unless the block has been changed the 200 should have some holes in the hood where the sign was unless that has been changed if the casting codes all over end with a Z or lower letter its an A example 6 7 Z means the casting was JUNE 7 54
Post A Followup
: Re: Re: Can anyone tell me which model I have a Super C or 200 ?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
