If you have some heavy jumper cables you can troubleshoot the problem. have someone hold the starter button down and then you go directly from the battery post to the starter post, having all contact points clean. If it speeds up significantly then you know where the problem is. Do the same on the ground side, go directly from the battery post to a clean shiny spot on the starter. Do this one side at a time, although if your cables are too small jumpering both sides may be necessary.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
