Re: need more front height on a C-SC, ideas?
Posted by NoNewParts on October 16, 2013 at 06:50:16 from (67.240.141.151):
In Reply to: need more front height on a C-SC, ideas? posted by NoNewParts on October 15, 2013 at 06:49:55:
NoNewParts said: (quoted from post at 10:49:55 10/15/13) I could use some ideas on a project I'm working on.
picked up a set of 12-44 tires at auction on a whim because
the brackets welded to the rim looked like they would fit a C-SC center.
They did. rice style deep lugs, very tall.
put em on a beater NF C I had.
ok, now need to raise the front...a lot
ideas so far:
put 7-15 trailer tires on the C front = couple inches up.
ideas and questions:
read that Farmall 404 has the same pedestal bolt spacing, true?
saw a 16" single wheel pedestal off a 404..will it fit a C?
also saw a 2 wheel NF pedestal listed as fitting a 340-404-504,
which would let me use 16" tires. will it fit a C-SC?
How about lug style hubs that would fit a C-SC spindle? any models that would fit?
a 6-16 or 6.5-16 would raise the C's front quite a bit, still wouldn't be level, but would be
much better than now :D
A wide front would work, but I would like to keep it narrow.
any ideas would be appreciated.
I won't really be using it for anything, just some scrap pile, 'wonder if this will work' type fun
Thanks for the reply's so far, more are welcome.
Even though the new tires are about 67 1/2" tall and the old 36's were about 52" tall,
only about 5" of lift in the front would help a lot.
I'll pick the front up with my hoist to check later.
Until I can find out if any 16" tire pedestal will fit,
I'm leaning towards combining your ideas.
tall 15" tires on the stock front end
(either trailer tires or old bias drag race fronts)
and building a spacer
out of 2 pieces of drilled 1/2" plate with a 1" plate sandwiched between.
(roughly, I'll need just enough space to get the bolts in)
about 2" total spacer should keep the strain acceptable.
thoughts?
those Super AV rims would be great, but are worth more than this tractor and those giant $50 tires.
I'll have to find some locally and take a look, maybe I could make some out of some old 19" Ford fronts I have laying around
This post was edited by NoNewParts at 07:02:00 10/16/13.
