Posted by PretendFarmer on October 16, 2013 at 08:10:10 from (192.249.47.207):
In Reply to: Super H stuck posted by mb58 on October 16, 2013 at 07:51:34:
As Zach said, replace the one bad piston and sleeve. Or you could just replace one piston with new rings and hone the sleeve. I replaced one piston with rings and a sleeve on my 140 and it has worked flawlessly. I wouldnt worry about the lower end bearings. When you disassemble, just make sure you put things back together correctly and torqued properly.
IF the bearings are bad, it will knock. You will know immediately if thats the case and you can replace them anytime. As some always say, if it aint broke don't fix it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
