Re: Farmall 140 PTO leak
Posted by gene bender on October 16, 2013 at 09:04:23 from (67.55.226.99):
In Reply to: Farmall 140 PTO leak posted by oldsudbury on October 16, 2013 at 08:19:22:
You over filled. That area gets its lube from the tranny slashed back thru a channel and your drain mite be plugged. If you dont use the belt pulley dont worry about it. The seal on he PTO shaftshould not leak. Did you check the lube level at the tranny behind the left brake rod.
