Re: 49 farmall h starting prblems
Posted by El Toro on October 16, 2013 at 14:43:32 from (96.244.7.206):
In Reply to: 49 farmall h starting prblems posted by ken walter on October 16, 2013 at 14:17:14:
Hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. Make sure your tranny is out of gear & brakes are set. If you have very little suction on your hand means you have low intake manifold vacuum. Also do a compression test. The engine needs good manifold vacuum to suck that atomized fuel into the combustion chamber. If the plugs aren't wet from choking, you're not getting gas. Hal
