Re: IH544 IPTO Housing Seal Ring
Posted by Owen Aaland on October 16, 2013 at 15:17:16 from (216.47.34.210):
In Reply to: IH544 IPTO Housing Seal Ring posted by John G. Hasler on October 16, 2013 at 13:02:50:
It is the sealing O-ring between the rear frame and the PTO housing. Later serial number tractors use gasket number 530690R1 instead of the O-ring.
