Re: 706 hydraulic remote lever hard to move
Posted by Owen Aaland on October 16, 2013 at 16:33:07 from (216.47.34.210):
In Reply to: 706 hydraulic remote lever hard to move posted by kevinbauer on October 16, 2013 at 16:19:46:
Is the valve spool hard to move or is it just hard to get out of the detents?
If the spool is hard to move you may have distorted the valve body when tightening the bolts or there may be debris between the valve bodies.
If it is just hard to get out of the detents remove the dust cover plug on the rear end of the valve and loosen the adjustment screw in the end of the spool.
