Re: Regular A
Posted by jgstrickland on October 16, 2013 at 18:03:49 from (71.82.36.253):
In Reply to: Re: Regular A posted by John M on October 15, 2013 at 05:16:22:
Did you happen to find the number for the guy with cultivators? If you can"t, don"t sweat it. Thanks for the attempt.
James
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
