Re: FARMALL VOLTAGE REGULATORS
Posted by Janicholson on October 16, 2013 at 18:17:11 from (74.60.94.18):
In Reply to: FARMALL VOLTAGE REGULATORS posted by PEOSTATIM on October 16, 2013 at 17:30:37:
If 6V the regulated voltage should be 7.1 to7.3 volts measured across the battery at 3/4 throttle and with a fully charged battery. 12v systems should measure 14.2 to 14.6 volts with the engine and battery as above. Adjusting a regulator (if new should not be needed. Adjustment has been outlined in the archives many times, but it is sensitive to variables and is not the thing to recommend to an electronic novice. A Motors Manual from the 1950s, or a Automotive Electrical Systems Diagnostics and Repair from that era is valuable. Jim
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
