I assume you have a generator, not an alternator. Is ammeter showing a charge and is voltage as noted by Jani below? Generator will show lower voltage numbers than alternator. 6.8 or 12.8. If no charge showing on ammeter, ground the field wire on gen to see if that makes it charge. Polarize generator per instructions in archives. Make sure base of regulator is well grounded. Must have good ground for reg to work. New paint will insulate base and reg won't work. If after all this and you get no charge when field wire is grounded, take genny to shop and have it checked and repaired. Take the reg when you go to the repair shop so they can check that too. Make sure to tell the shop which ground you have, positive or negative.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
