Re: super a runs bad when warm
Posted by Kelly Barnett on October 17, 2013 at 05:00:55 from (208.87.232.180):
In Reply to: super a runs bad when warm posted by pork on October 16, 2013 at 15:19:56:
It may be just me but what is the valve clearance in the engine. When cold the valves might have enough clearance to work pretty well. Then as the engine is warming up the valves grow and the clearance disappears holding the valves open slightly. This will give the engine a doggy symptom. Without having a dead spark issue like a coil getting hot I would think it would be mechanical with the valves. It isn"t a big deal to lift the hood and valve cover to check this. Maybe since the engine rebuild the valves are seating in a little farther then when the engine was first done. Just a thought.
