If all else fails and while this may be wayyyyyyyyyy more then you asked for, if you work through my Troubleshooting Procedure it may help determine the cause of poor charging. In Para 5 it shows how to effectively by pass the VR function by dead grounding the gennys FLD post which will show what then genny can do (or not do) in that forced full output situation. If the charge is still weak with FLD grounded, the problem is the genny itself (or its wiring or its ground etc) NOT the VR. BOTH the genny and VR need a good ground to work properly.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
