Re: 2096 case vs. 986 /1086
Posted by farmallman1949 on October 17, 2013 at 09:26:31 from (70.195.65.242):
In Reply to: 2096 case vs. 986 /1086 posted by VA Gasman on October 16, 2013 at 17:14:03:
The 2096 is a great tractor for light work (cutting and baling hay, spraying) but is worthless for doing heavy work (tillage) and is acceptable for medium work (planting). It is only rated at 120 hp. where as the 986 is 106 hp. and the 1086 is 130 hp. In theory the 2096 should out pull the 986 but it won't the 986 is around 11,000 lbs. with out added weight the 2096 weighs just a little bit over that with add weight. And the 1086 will run away and hide from both the 986 and 2096. So in my mind the 986 or 1086 would be the way to go if you find a guy that is good with IH tractors to fix the shifter issues. If you get either of the IH's I would recommend dropping this man a line and have him explain things to you.
Charlie's Repair
22195 State Hwy. 56
Austin, MN 55912
Cell# 507-438-8172
email - charlieu@gofast.am
Web site - www.charliesrepair.com
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
