Re: FARMALL VOLTAGE REGULATORS
Posted by Gerry Powell on October 17, 2013 at 13:44:11 from (173.172.71.204):
In Reply to: FARMALL VOLTAGE REGULATORS posted by PEOSTATIM on October 16, 2013 at 17:30:37:
I have 3 Farmalls and just converted my SA to 12v. I've had charging problems for quite awhile and decided it was my regulator. While I was at it I rebuilt the generator will all new armature, coils, brushes, bearings and wick. Not hard to do at all but $$. I ordered a regulator from a major tractor parts supplier and it didn't work out of the box. I took the cover off and was amazed at the junk from China this parts supplier is selling. The contacts didn't meet right, it looks like the person testing the regulator bent the top contact about 45 degrees to get the right gap. The two contact surfaces are supposed to be oriented directly in line with each other and the faces parallel. One of the smaller guage wires where it's soldered to the frame was cold soldered. In all, a nasty piece of cr#$. Then I ordered one from Advance Auto and it is American made and it works but the quality is substandard as compared to the old days when electromechanical regulators were all that was used. I think it's a lost art and has seen it's days. That's why I decided to use an alternator. Generators are easy enough to rebuild, but I don't think it's possible to get a good working well designed old fashioned electromechanical regulator any longer to go with it. Now if you wanted to buy about a half dozen Chinese regulators and try them until you found one that works, maybe but I'm not made out of money.
Gerry
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
