Re: Camshaft gear fell off.
Posted by Owen Aaland on October 17, 2013 at 17:54:03 from (216.47.34.210):
In Reply to: Camshaft gear fell off. posted by markalayne on October 16, 2013 at 16:05:39:
The oil slinger uses centrifugal force to through the oil off of it to keep the oil away from the front seal. The rear seal slinger is built into the crankshaft.
This post was edited by Owen Aaland at 17:54:59 10/17/13.
