Re: Farmall M---care and feeding after overhaul
Posted by D Slater on October 17, 2013 at 18:21:56 from (184.14.160.234):
In Reply to: Farmall M---care and feeding after overhaul posted by zooeyhall on October 17, 2013 at 17:47:19:
Start up and get the engine to operating temp, cover radiator if needed and check for any problems during the period. Try for the shortest time. Operate at 3/4 throttle in 4th gear no load for 15 minutes. 45 minutes at 3/4 throttle on light work. Run it 2 hours full throttle on medium to heavy work. Check for leaks and check valve adjustment. May as well check the head bolt torque when doing the valves. With a victor type head gasket it may not change in 3 or 4 hours, but better safe than sorry. Put it to work and change the oil after 25 or so hours and the valves and head torque again. Tighten only the head nuts that are below torque and don't loosen any that are up to torque setting.
This is just a general guide and I'm sure you will get other opinions.
If the engine is rebuilt with everything in spec don't be afraid to go with it unless a problem is noticed. easy to break in to easy as it is to hard.
