Posted by Zachary Hoyt on October 18, 2013 at 03:58:13 from (74.47.60.126):
In Reply to: Radiator swap on H posted by Dan T in MO on October 17, 2013 at 21:52:45:
You do not need to remove the cap with four bolts on top of the front end casting. If you unscrew the large pipe cap on the front of the steering gear box and remove the bolt in the u joint you can turn the worm gear shaft right out the front of the gearbox. You will also have to remove the half moon key at the U joint end once you have turned the shaft far enough forward to be able to get at it. Zach
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
