Re: Flail Mower
Posted by GarryinNC on October 18, 2013 at 15:50:07 from (66.226.53.231):
In Reply to: Flail Mower posted by Richard I on October 17, 2013 at 08:27:31:
I have two alamo flails that I got in a trade and what they will cut depends on what type/weight of knives it has on it. The one that does best for me has the heavier knives attached to the drum with a clevis and pin. The other one has lighter/longer knives attached directly to the flanges on the drum. It works better in shorter grass and leaves a nice finish. It is a 6ft. cut.
The 7ft has the heavier knife set up and I cut johnson grass and weeds as tall as the tractor.These knives have a higher tip speed than the six footer. The weeds cut better than the johnson grass on the first pass. Heavy patches of johnson grass require me to drop down a gear and/or make a second pass.
What I like about flails is the way they 'shred' the material and leave it even on the field. Another bid plus is that they will pick up and cut your tracks out. Assuming that the mower is wider than the tractor tread width, or somewhat offset. I use it behind a Massey 253(48hp). Have not had it behind M or MD. We do use an 8ft rotary cutter behind a Super MTA diesel. That is all it can stand in heavy grass.
Garry
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
