Re: Case IH CX90 or JX95 tractor experiances ?
Posted by HydroTek on October 18, 2013 at 17:53:59 from (69.27.61.74):
In Reply to: Case IH CX90 or JX95 tractor experiances ? posted by jd720 on October 15, 2013 at 17:21:24:
Go with the CX and stay away from the JX (The older JX had thru the floor pedals and the later had hung pedals) ...the still later Farmall replaces the JX and is a good tractor. The Iveco engine is solid, not a problem there. The problems with the early JX were mostly electrical, AC leaks and pto
