Posted by Owen Aaland on October 18, 2013 at 18:30:10 from (216.47.34.210):
In Reply to: 806 PTO posted by lee little on October 17, 2013 at 19:28:45:
Like Pete I rebuilt many of them in the field. Put the front end down in a ditch. I had a bracket I bolted to the draw bar to hold the PTO assembly after I pulled it out. After rebuilding them I would slide them back in the tractor and bump the starter over just A bit to line the shaft and coupler.
Those units are a lot heavier today than they were 30 years ago. Today I do them in the shop where I can use the cherry picker.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
