Re: IH544 IPTO Housing Seal Ring
Posted by HydroTek on October 18, 2013 at 18:32:15 from (69.27.61.74):
In Reply to: IH544 IPTO Housing Seal Ring posted by John G. Hasler on October 16, 2013 at 13:02:50:
The ring you mention was used on the face of the PTO housing ..there would have been a groove for it to sit in, otherwise a gasket was used. Either way, if there are no leaks = a job well done
