Re: SA Quit, Where to Start
Posted by HydroTek on October 18, 2013 at 19:05:48 from (69.27.61.74):
In Reply to: SA Quit, Where to Start posted by oldtractorfun on October 16, 2013 at 20:49:49:
Several ways to do this, ..but a test light to the resistor is quick(see if there is power), from the resistor to coil, test light will dim as the points operate. Check the distributor side of the coil as you crank over the engine(test light should pulse as the points operate)
if above is good, then
Lay the coil high voltage wire next to a ground and check for spark, first directly, then thru the distributor cap
