Case International 485 Lift Problems
Posted by Russell Moore on October 18, 2013 at 20:12:30 from (74.177.128.77):
Our Case IH 485 has started giving some problems with the lift
when you raise the lift leaver with the draft set about mid way hooked to our 3pt disk harrow the lift jumps and is very slow to come up it does the same when lifting the 6ft bush hog
it also makes grinding sounds when using the bush hog with the pto on and raising the lift
we used the hydraulic harrow today and it seemed to work fine
does anyone have any ideas we have changer the hydraulic filter just last week thinking it may be clogged but it didn't help any
Thanks
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
