Re: FARMALL VOLTAGE REGULATORS
Posted by Tom Fleming on October 19, 2013 at 07:09:23 from (67.20.233.75):
In Reply to: FARMALL VOLTAGE REGULATORS posted by PEOSTATIM on October 16, 2013 at 17:30:37:
Well, a good bit of this has been covered by previous posters, so I will summarize and state what I know.
Most common problems I have found in order of occurrence:
1.) Dirty connections on wires: battery cables, VR connections, amp meter connections, generator connections.
2.) generator not properly polarized
3.) dirty commutator or worn brushes in Generator
4.) failed voltage regulator or cut out.
I prefer the US made Vr's, which are more expensive but also better quality.
People can disagree (and will), but a properly maintained, clean generator system will work and work well. Problem is, people don't want to take the time to maintain, nor for the most part, do they understand a generator system. Conversion to an alternator is immensely easier to maintain. 12v makes battery purchase easier on the wallet. However, neither will out perform a properly working 6v generator setup in my humble opinion.
If I had a true working older tractor, I would probably convert minimally to an alternator because I want to spend my time using it, not maintaining it (any more than I have to). My show tractors do some work, and always will, but that is not my source of income, so I can take extra time to tinker and maintain the generator and electrical systems. My thoughts........your mileage may vary.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
